I am a big fan of using the MstnFontConfig file to minimize the number of fonts available for selection in the text editor.
Sometimes there are many variations on a particular font, for example, "Highway B", "Highway C", "Highway C Plus", etc.
Is there any way to use wildcards in this process? For example, can I type "Highway*" and have all of the Highway fonts load?
Here is a spoiler for you, unless I'm missing an escape character, I've tried Highway*, Highway%, I've even used RegEx expressions, none of them seem to work.
Any insight is appreciated.
Just out of curiosity: why do you have those variations of fonts? iI it just the name and the fonts are really different or are they pretty much slight variations?
Hi Tim,
Unfortunately I don't think this approach will work in this instance, according to this link, the <Name> node is a "Comma-separated list of TrueType font names to which these settings apply." therefore it sounds to me like you have to explicitly provide a list of font names to show or hide.
However, this task can be made easier:
[System.Reflection.Assembly]::LoadWithPartialName("System.Drawing") (New-Object System.Drawing.Text.InstalledFontCollection).Families | Out-File -FilePath "C:\FontList.txt"
At this point you now need to make a decision, you either make a list of all the fonts you want to be visible, or a list of those you want to hide.
Answer Verified By: Tim Letcher
Gerd,
I don't know what the difference is between them. However, this is the second customer to supply me with fonts in this type of naming convention.
The first customer gave me all variations on Engineering*.ttf. That was only eight fonts, so no big deal; I just wrote them all out. The second customer gave me the variations I described above, but this time there were 22 different fonts in that naming convention. I invested a bit of time in getting a wildcard to work, but I was unsuccessful. In defeat, I wrote them all out again.
I assume wildcards work in this file and that I'm just getting something wrong with the syntax.
Barry,
I like this idea a lot, especially if wildcards are not possible.
I only dabble in PowerShell; clearly, you are on a whole other level.
I am going to take your code and tweak it to my needs but follow the same workflow. I have never installed the fonts on my PC; they reside in the font folder for that specific customer. So, I should be able to output a list of files to a text file and then follow the workflow from there.
This was great insight, and thank you very much for the detailed procedure.
Tim Letcher said:I only dabble in PowerShell; clearly, you are on a whole other level.
Oh I wouldn't go that far, it was actually as a 2nd resort; My initial thought was to use a VBScript:
Const FONTS = &H14 Const ForReading = 1 Const ForWriting = 2 Dim objShell, objFolder, objFolderItem, objFSO, Folder, Font, FontList() Set objShell = CreateObject("Shell.Application") Set objFolder = objShell.Namespace(FONTS) Set objFolderItem = objFolder.Self Set objFSO = CreateObject("Scripting.FileSystemObject") Set Folder = objFSO.GetFolder(objFolderItem.Path) i = 0 For Each Font In Folder.Files If Right(LCase(Font.Name), 4) = ".ttf" Then Select Case i Case 0 ReDim FontList(i) Case Else ReDim Preserve FontList(i) End Select FontList(i) = Font.Name i = i + 1 End If Next For a = UBound(FontList) - 1 To 0 Step -1 For j = 0 To a If UCase(FontList(j)) > UCase(FontList(j + 1)) Then temp = FontList(j + 1) FontList(j + 1) = FontList(j) FontList(j) = temp End If Next Next Dim FSO Set FSO = CreateObject("Scripting.FileSystemObject") Set OutputFile = FSO.CreateTextFile("D:\FontList.txt", True) 'OutputFile.Write (Join(FontList, ",")) For Z = 0 To UBound(FontList) OutputFile.WriteLine FontList(Z) Next Set OutputFile = FSO.OpenTextFile("D:\FontList.txt", ForReading) strLine = OutputFile.ReadAll intlength = Len(strLine) strRemainder = Right(strLine, intlength - 1) If InStr(strLine, ",") = 1 Then Set OutputFile = FSO.OpenTextFile("D:\FontList.txt", ForWriting) OutputFile.Write strRemainder End If Set objFSO = Nothing Set objShell = Nothing Set objFolder = Nothing Set objFolderItem = Nothing Set Folder = Nothing Set OutputFile = Nothing
However this results in output like this:
462364.ttfAGENCYB.TTFAGENCYR.TTFALGER.TTFANTQUAB.TTFANTQUABI.TTFANTQUAI.TTFarial.ttfarialbd.ttfarialbi.ttfariali.ttfARIALN.TTFARIALNB.TTFARIALNBI.TTFARIALNI.TTFARIALUNI.TTFariblk.ttfARLRDBD.TTFArtifaktElementMedium.ttfArtifaktElementRegular.ttfbahnschrift.ttfBASKVILL.TTFBAUHS93.TTF
The script also lists TTF files which aren't visible in MicroStation, but the file name not matching the Full Name of the font was the main reason for switching to Powershell:
The Powershell output does match the font pulldown however, the only issue is that the Asian fonts prefixed with the @ symbol don't get listed by either script and need to be hand written to have them hidden from view.
