The "Export Google Earth File" (KML) should consider the previous selected elements not all the visible elements in the active Model.
And options if we want to ignore References, etc... according to the typology of the elements. ( I would like to see a settings dialog similar when we convert) in this case to export to Google Earth, to filter objects, etc...
It would be also nice if we could select the format file (KML,KMZ or GPX)
Joan Martínez Serra said:The "Export Google Earth File" (KML) should consider
Post your suggestion to the Ideas Forum.
Hi Joan,
You can easily export only selected elements to GoogleEarth by using a displayset.
The KMZ file created by exporting is basically a zip file containing a KML file, and depending on the Google Earth Settings it may also contain other items such as images or collada files.
Regards,Ron
Answer Verified By: Joan Martínez Serra
