Hello -
Is there a way to see what element a label is associated with? Is there a way to re-associate a label with a new piece of geometry after it has been placed? Is there a way to copy labels so I can keep the settings?
Nader Mostafa said:Is there a way to re-associate a label
I'm thinking that the use of the Modify Element tool might help to re-associate a label.
Labels re-associate/update cell
Nader Mostafa said:Is there a way to copy labels
Depending on how the Label was placed / produced you should be able to use the Copy Element tools after it has been selected.
Nader Mostafa said:Is there a way to see what element a label is associated with?
Not sure exactly why you might require this type of operation.
You might like to provide further details and possibly example design files / screen captures to help explain your issue.
Here are some useful links about this topic:
Place Label
Bentley Learn Server- Place Label
Tips & Tricks- Place Label Cell Filter
