I am trying to open an open bridge designer file and get the following error. The file is located in a projectwise datasource Does anyone know why this would be happening? The file was working for someone else on Friday. It may be a corruption issue but I don't know.
Josh
Hi Josh,Did you find any solution for the concern? I am facing the same issue at my end.Using managed workspace and OpenRoads Designer.ThanksDeepak Singh
If it is related to ProjectWise then ask in ProjectWise Design Integration Forum
You have to assign correct MIME types and reset any custom assignments by user.
