Dimension Style - Reducing Fractions
When using a dimension style provided to us, it seems that MicroStation is not reducing the fractions. The accuracy is set to 1/16 and the Retain Fractional Accuracy is off. When we create a new dimension between two referenced elements that are 1/2" apart, the dimension shows 8/16". We noticed that if we draw two lines 1/2" apart and add a dimension to that, it shows correctly as 1/2" in the dimension.
Has anyone noticed this behavior when dimensioning elements from a reference? We've tried to check/uncheck the fractional accuracy, but the same behavior persists.
Ken
ORD CE 2021 Release 1
