I'm receiving the error "VBA Interface Error: failed creating the comp manager - 0x80040583" when trying to use one of the tools in Microstation. Following the instructions on one of the previous posts, I loaded "Prerequisites for Bentley Desktop Applications" (file name: pbda08110903en.exe) and installed but this did not correct the issue. Please advise of other options for correcting this issue.
MicroStation CONNECT Edition Update 1 - Version 10.01.00.13
Jason
Hi Jason,
Jason Sauls said:and installed but this did not correct the issue.
As Rod Wing wrote, the prerequisites are valid fro V8i generation only. It does not interact with CE products, because V8i is 32bit, whereas CE is 64bit application.
Jason Sauls said:MicroStation CONNECT Edition Update 1 - Version 10.01.00.13
Thanks for sharing this information (many people forget it, thinking it is possible to discuss issues without knowing product and version ;-)
It is extremely old MicroStation CE version, with "early beta" quality. The current version is CE Update 16.1 and there, so there are about 18 versions between Update 1 and the current one.
Jason Sauls said:Please advise of other options for correcting this issue.
Did you search this web for similar discussions? You can find plenty of them, so I recommend to check them whether some from advises is applicable to your situation.
With regards,
Jan
