Hei
Does somebody know why some layers in my reference are on a default layer but when I open that file, these layers are not on a default layer but different ones?
Refernces can be given a layer in the settings menue of the reference.
I just want my referense (cal it x.dgn) to have the same layernames as when I open the x.dgn file...
What is a layer???
can you provide a screenshot and/or a example of the file(s) that you refer to.
Levelnames should be the same with the attachment as when you open the file directly.
When I take my "Hverfið mitt 2021-2022-grunnur-2d-YFIRLITSMYND.dgn" under as ref..... I get many layers as default-layer (first picture)... when I open my "Hverfið mitt 2021-2022-grunnur-2d-YFIRLITSMYND.dgn" many more layers appears (second picture).
