I can't export or save as a dgn-file (Bentley PowerCivil for Sweden V8i (SELECTseries 4) ) to dwg-format (using Civil 3D 2019 Metric). It have worked before but no I only get the message:
What to do?
HI Sofia
This could be the path to your DWGSeed file. If it is not valid this message appears. If you go to the configuration variables settings and look for DWGSEED it will show you the path and filename. make sure it is correct.
Ian
I only have this in my configuration...something has happened:
Am I in the wright location? Under the category DWG/DXF it's missing to. How to I restore it and/or get the correct path?
Maybe this (relatively old) article can help with the seed file. It is for normal MicroStation but the structure should be the same for PowerCivil. Save as DWG Error "Unable to open seed file <filename>.dwg" - MicroStation Wiki - MicroStation - Bentley CommunitiesIn your screenshot you may switch to "Seed Files" at the bottom of the left column in the window. If there is no path defined, normally you should find a DWG seed file in the program files of your installation, the default path should be something like: C:\Program Files\Bentley\[PowerCivil]\Default\SeedNot sure how the PowerCivil Installation Folders are named, so maybe this part looks a bit different.
Currently using:
OpenPlant Modeler - Version: 10.09.00.74
[MicroStation - Version: 10.14.02.01]
