Hi all
Is there a good way to export text or text nodes to a Google Earth KMZ file from MicroStation/ OpenX Connect Edition?
Currently text is exported as shapes/ fills, which can make a KMZ file really large and slow (in addition to it not looking very neat). I was hoping each text node could be exported as a point/ Placemark with the Placemark name being the text in the text node.
Is there any way to do this, either natively or by a macro?
Hi Ron
Thanks for the suggestion. I tried to create a new property filter, but I could not find a Text Node/Content/Text String property to add to the filter. Text/Text String does not seem to work on Text Nodes but only Text Elements.
From what I've seen of the export options and doing some basic testing, MicroStation can't give you what you seek aside from the line geometry. I think the only way to achieve those pin marks is:
There might be a way to do some of the work in Excel, perhaps somehow being able to import data from a CSV. Its just conjecture on my part as I don't do anything with Google Earth.
