Hei
I have many long level-names. Is it possible to see the whole level-names in my Home-ribbon?
Hi Sigríður
Try setting the configuration variable MS_LEVEL_PICKER_WIDTH to a different value ( The value is the number of pixels so its dependent on your screen resolution)
e.g. MS_LEVEL_PICKER_WIDTH = 200
start with 200, see how it looks. If its too wide, reduce the number, not wide enough then increase the number
You can graphically change the width to accommodate long level names.
Sigríður Brynjólfsdóttir said:I have many long level-names. Is it possible to see the whole level-names in my Home-ribbon?
On the bottom right of the pulldown you will notice 3 triangles you can click and drag to resize the pulldown.
Thank you :-)
