I have several lines, with points at every 40' and need to add vertices at every 5'. Is there a way to do this in OpenRoads Designer?
I'm not sure why you would ask in the MicroStation forum, you would be better asking in the OpenRoads forum:
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum
OK Thanks
It should be available in ORD as well but the "Facet Curve" tool should do what you need:
docs.bentley.com/.../DropBsplineCurve.html
Can that be used on ORD features?
MaryB
I dont know if they can be used directly but you should be able to drop the feature to a normal linestring use the facet tool and then convert back to a civil feature.
