Using CE16 I have found that Create Region now doesn't keep the previous options set, but SS10 does. If I set the option Fill Type to Opaque it works OK, but if I go out of the tool and then come back to it Fill Type has reverted to None. This is a pain as I need to remember to change to Opaque each time. This is a new bug as far as I can see as I'm sure it worked OK in U15.
Can you confirm the specific version you are using? If you manually save settings does the tool retain the desired settings?
I've just tested in vanilla U16.1 and it seems the settings stay as previous between command calls. So probably it's fixed in U16.1.
David Trejo-Rodriguez said:Can you confirm the specific version you are using?
10.16.01.56
David Trejo-Rodriguez said:If you manually save settings does the tool retain the desired settings?
It does as far as I can see after a quick test but this is a change as to how the tool works in other versions. I don't normally manually save settings whilst working in a file. Why the change?
Tuan Le said:I've just tested in vanilla U16.1 and it seems the settings stay as previous between command calls. So probably it's fixed in U16.1.
It only works after doing a manual save settings which is a change from previous versions!
