Using CE16 I have found that Create Region now doesn't keep the previous options set, but SS10 does. If I set the option Fill Type to Opaque it works OK, but if I go out of the tool and then come back to it Fill Type has reverted to None. This is a pain as I need to remember to change to Opaque each time. This is a new bug as far as I can see as I'm sure it worked OK in U15.
not what I'm seeing Stuart. Settings stay as they were for me between command calls in 16.1 without me hitting Save Settings.
It might be an issue with the upf not being updated when a tool settings is changed then. Might be able to test if you open up the prefs folder and see if changing a tool settings updates the upf. Might need create a fresh upf the following might help in saving your current settings:
communities.bentley.com/.../create-and-configure-connect-seed-user-preference-files-upf-xml
I can't replicate your issue either Stuart.
I'm running U16.1 it works as it always has. I change the Create Region tool settings, click a few other tools, place some other elements, then come back to Create Region and the settings are the way I had left them.
I even did an Undo All and the tool settings did not change.
Have you tested this in different dgn files? Perhaps it an issue with certain dgn files.
Rod WingSenior Systems Analyst
Rod Wing said:Have you tested this in different dgn files? Perhaps it an issue with certain dgn files.
I have and it's the same in all files. Never happened before in any version before this one.
are you using a custom workspace ? Try doing this with no configuration applied.
Timothy Hickman
Main: 877 627 3772|
