After uninstalling Powerdraft CE 14 German VBA projects no longer load in Microstation 16.1, neither automatically as set nor manually.
The following error message is displayed (German):
Any ideas what I have to reinstall?
Run the repair of Microstation installation. One of not so nice features of VBA as it is not part of main program and may or may not work. Some Windows updates may also break VBA for application time to time. Hassle free upgrade from Powerdraft to Microstation? Hope you configured entitlments and blocked Powerdraft so won't get any surprise later.
Is there pre-requisites for the latest CONNECT, as per V8i?
Sometimes need to restart after older version uninstall otherwise this can happen. Or this time it seems that Powerdraft uninstalled VBA without looking that Microstation install still exists.
It all worked fine until I uninstalled Powerdraft... restarting the Computer didn't change the behaviour. Will run repair now and get back.
There's a grace period of two quarters - the one during which I upgrade and the subsequent one.
f.mandoki said:There's a grace period of two quarters - the one during which I upgrade and the subsequent one.
Let's see. It was also said first 10min interval are not counted but even then some surprises pop up.
