Hello Good MS community,
I have a question regarding point cloud visualization.
I created a section line in a model that contains an RGB Pointcloud and then the respective Drawing Model in dynamic view, but unfortunately I can't seem to see the point cloud in RGB color in the 2D Drawing Model.
I tried managing the presentation from the reference toolbar but is not working.
Any idea why?
Rafael
Hi Rafael,
are you working in CONNECT?
which version do you use?
what software generated your point cloud? which point cloud format?
do I understand correctly that you see the RGB color when you attach the point cloud but issue only happens after creating a section line in the model?
Could you please confirm that you have set from View attributes -> enable Point Cloud style RGB color?
could you please provide a Screen shot with your results and also the point clouds for our review?
Maria
Hello Maria,
I'm working on CONNECT Update 8
That is a very old version. We are now in update 16.1 (10.16.01.56).
Let me know if you still have the problem in the latest update.
The thing is that this is Microstation for OpenBuildings, and I think is the latest version
OBD Update 8 is indeed the latest version. But don't let that confuse you, it doesn't mean it's based on MS Update 8. Not sure where to find the exact MS version it is based on, but I think it is MS Update 15.
