Microstation Item Type - Expression Syntax Definitions to calculate Length, Width, Height for cells/elements
Hello Everyone
I am trying to create Expression Syntax Definitions to calculate Length, Width, Height (XYZ) when attaching item types to existing cells/elements.
So far ,XYZ values have been difficult to automatically define in item types.
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/ec-expressions-in-item-types---new-in-microstation-connect-edition-update-12
The above link gives some handy information and a list of pdf syntax.  However I cannot see anything suitable to generate XYZ data.
For example RAW dgn data shows the below for a cell:
Here is an example expression for volume
this.GetElement().GetDisplayValue("Volume")
Is it possible to do something similar with XZY values?  Or use the RAW data (Range Low) minus (Range High)?
Parents Reply Children
