I have produced a reality mesh in contextcapture using coordinate system EPSG:2288 NAVD88, the model was reconstructed correctly, HOWEVER, I bring the model into microstation to perfrom a ground extraction (I have set the matching coordinate system), while the XY coordinates are correct, the Z is 200' higher that the context capture model.
Please help explain how to fix this?
yes, I have a Descartes ribbon extension in microstation, that is what I used
Marcia, attached two photos show my issue, one photo is contextcapture viewer in which the 3SM is correctly showing the coordinates for control point #13 (Z=1186.46), however when I being into microstation (other photo) Z=1301.11. I have matching coordinate systems for both, cant figure out what I did wrong
