Usually we store all our custom line styles in one .rsc.
But now there's two line styles that appear in my list that I can't find in any of the .rsc files stored in our company network. And of course these are the two I want to adjust.
Is there any way to find out exactly where these stem from?
If you drop down the line style list, at the very bottom there are 2 options, Settings & Manage. Select Settings. A dialog will open and you can scroll through the list of line styles. When you highlight a line style it will show you the file path to the library or if the style is part of the active drawing it will show the path & name of the active file.
Power InRoads v8i 08.11.09.615
Microstation CONNECT 10.16.02.34
Microstation v8i SS 10 08.11.09.919
ORD CONNECT 2021 R1 10.10.1.3
ProjectWise 10.0.3.453
I have found that, too but it says the line style is in a .dgnlib. But I can't edit that line style in that dgnlib because the line style editor doesn't show it.
I am new to working with .dgnlib for line styles. I believe you need to import the line styles from the .dgnlib into a .rsc file. Make your edits to the line style then export it back out to the .dgnlib. Once done, all files that use that line style need to be updated for the change to be visible. I just read a few forum posts on it yesterday as we have a client that is using the .dgnlib for their line styles. It is not a cut & dry process. I would suggest searching "edit line style .dgnlib" for more information. Their may be some stuff in the help file, but from what I have seen it is vague. I'll see if I can find those articles and post links
Answer Verified By: f.mandoki
mwlong said: I believe you need to import the line styles from the .dgnlib into a .rsc file.
That worked, thank you.
Glad it worked. Here is Part 3 of a series of line style blogs. This one deals with updating the line styles from the dgnlib to the dgn file.
communities.bentley.com/.../custom-line-styles-part-3-updating-custom-line-styles-stored-in-a-dgnlib
