Usually we store all our custom line styles in one .rsc.
But now there's two line styles that appear in my list that I can't find in any of the .rsc files stored in our company network. And of course these are the two I want to adjust.
Is there any way to find out exactly where these stem from?
Project Explorer also lists linestyles but is of no use. RSC workflow is so outdated.
For future reference the following articles detail finding where linestyles are stored and how to update those located in dgnlibs:
https://communities.bentley.com/products/microstation/w/microstation__wiki/38049/how-to-find-out-what-custom-linestyles-are-stored-in-a-dgnlib
https://communities.bentley.com/products/microstation/w/microstation__wiki/38051/how-to-edit-and-delete-custom-line-style-s-from-a-dgnlib
I don't really use Project Explorer, but since you mention it I opened it in some files and looked at the line styles. There is very limited information. It does report whether the style is part of a dgn file or a Resource File, but it does not report the name of the file it resides in. You are correct that there is no real use at this point within PE.
I'd actually prefer to work with .rsc because updating line styles in a .dgnlib then pushing those changes to files is very cumbersome. The worst part about .rsc is the line style editor dialog.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
What are the advantages to saving linestyles to a dgnlib if you can't edit them?I mean, I guess that's an advantage in some ways...but if you cannot create nor edit linestyles in DGNLIB files, why do it? Why not stick with RSC files?
MaryB
Why not stick with RSC fonts? Why use Truetype? Why we need more than 63 levels?
How CONNECT is more productve if we still use MSJ era workflows it is beyound me...
