[MS CE 15.2] References files path to OneDrive folder
In our company, we are now using onedrive to store our CAD projects
We are facing a problem with the path for the reference files
If I attach a reference path it uses my Windows user directory :
C:\user\[MYWindowsLogin]\OneDrive-Of-My-Company\Project Folders\Shared Project\ReferenceFile.dgn
So, when a collegue opens the file, obviously the reference file  is not found because his windows login is different.
Using relative paths does not help. Not sure that MS_RFDIR can help either because we have a lot of project directories
Any ideas ?
Many thanks
Parents Reply
  • This is no different than previous uses of MS_RFDIR. Any time a new project was introduced, and there were no project-specific configurations, MS_RFDIR would have to be updated to include those new project directories.
    One option to streamline this a little may be to store your Microstation workspace, configuration, and resource files on a network drive, so that everything is controlled from one location, instead of being saved locally on everybody's computer. That way, there can be a procedure when new projects are added for one person to update the MS_RFDIR path, which would then be used by everyone.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
