I have an Item Type containing properties that uses an expression to display Sheet information (name, number).
If I place a text field using this info it will display the correct data but if I update the Sheet info the fields are not updated (I've executed FIELD UPDATE ALL and model properties Update Fields Automatic).
Existing and reopen the file will update the fields.
Test file attached.
/Krister
ItemTypesExpression.dgn
Hi Krister,
thank you for your file, I am investigating your issue. I was able to reproduce when you place the text. I will double-check with developers before I fill a Bug, I try to find also a workaround to suggest to you.
My regards,
Benedetta
I would like to notify you that the problem you have described is a BUG 773420 "SheetData Item Type does not update after change Sheet Index properties ".
As I previously notified you, I suggest using Place text> Insert Field Model Properties and pick the name and number of the Sheet. In this way the update is immediate.
I raise a ticket for you and I will keep you updated regarding the Bug.
Thank you very much for reporting this issue.
Thanks!
I still have problem if I want to use this approach (Text Field, Model Properties) in a cell. I will get back with more details.
Owner consultant at Surell Consulting AB
I created a video to share with you, we can discuss your issue by the ticket that I opened.
I have no problem creating cells. If I just use a text field with model properties it works fine (like you showed).
I have attached two files, a cell library and a test file. The cell "Stämpel" contains both text fields from Item Types and a text field using sheet model properties. When the cell is placed in the test file the link to the sheet property is broken.
/KristerTextFieldProblem.zip
