I have an Item Type containing properties that uses an expression to display Sheet information (name, number).
If I place a text field using this info it will display the correct data but if I update the Sheet info the fields are not updated (I've executed FIELD UPDATE ALL and model properties Update Fields Automatic).
Existing and reopen the file will update the fields.
Test file attached.
/Krister
ItemTypesExpression.dgn
Hi Krister,
I tested your file and the cell library. If I update with the tool "replace cell" I am able to see the Sheet number but only the model properties from the cell library. If I change the Sheet number of the model of the dgn I lost the association of the Item Types.
I tried to create two different cells: one with the item types and one with just the Sheet properties, but the association with the Sheet of dgn is lost. It seems that the sheet properties lost association every time. I keep investigating this.
Benedetta
I would like to notify you that the problem you have described is a BUG 787874 "The Link is broken when a cell (combination of item types of the model and one text with sheet model properties) is placed in a dgn file".
I raised a ticket for you and I will keep you updated regarding the Bug.
My regards,
Hi Benedetta, Just wondering if there is an update on this bug ?. I believe I am experiencing the same problem. I have attached a series of item types to a sheet model. I have a cell (Which i created in Update 15) that has fields that display these item type values. In certain circumstances, the fields are not updating when placing the cell
Hi Darren,
the bug is approved. I raised the priority for both of the bugs, if you want I can open a ticket about your issue and update through regarding the bug.
