Hi
I am running MicroStation Connect updt. 16 and ProjectWise Explorer 10.00.03.434.
I am having trouble connecting to a MS Access database when I have started MicroStation through ProjectWise.
When I start MicroStation outside PW I can connect fine.
Through PW the variable MS_SERVER is cleared. This happen when I press the Browse icon (the three dots) in the connect to database settings dialog.
Before trying to connect:
Then pressing Browse
The result:
I don't even get to browse for the ODBC name.
The ODBC datasource is a 64 bit connection.
Any other there have experienced something like this?
you may want to post this in the PWise forum - they might be familiar with this type of issue.
Timothy Hickman
Main: 877 627 3772|
