My company recently updated from V8i to CONNECT.
In V8i there was an MDL application that we used frequently to import text associated with survey coordinates called pltpnt.ma
It appears that this MDL app is not compatible with CONNECT.
The XYZ Text Import Coordinate tool built into Microstation only has the capability to import coordinates and does not have the capability to import text associated with the coordinates. The pltpnt MDL app does have this functionality.
Does anyone know if there is a pltpnt MDL app that is compatible with CONNECT?
Or is there an alternative method of importing text from an external .txt or .csv file?
You could try Import Points module - https://communities.bentley.com/products/programming/microstation_programming/b/weblog/posts/import-points-ce-2-0-released-to-the-microstation-community
We also tried to migrate pltpnt.ma to CONNECT so have to check if it may work as expected.
page no longer exists, could you please re-upload?
Štefan Šuba said:page no longer exists
Try this, which I found after searching Be Communities for import points.
