Trying to label a line in a reference file to show the bearing directions in Connect but the dimension doesn't show up correctly and there are no directions. Here are the design file settings:
Here is an image of the reference file label (top) and an active line label (bottom):
Is there some new config variable in connect that you need to set so that it dimensions reference elements the same as active elements?
I've filed a BUG 786189 for this issue.
Thanks for reporting,
Manoj
