I'm trying to get a better understanding of the capabilities in building Parametric Cells in Microstation.
For the moment I can build a parametric cell make variations by adding values into each Variable in the Variation. It's a time consuming and a tedious process.
The question is then, is it possible to read the data directly into Variation variable from an Excel or a CSV file?
Thanks in advance
Ole Bro
Ole Bro said:Is it possible to read the data directly into Variation variable from an Excel or a CSV file?
Submit an Idea!
Thank you Jon,
I take your answer as a "No"
I will submit the question as an Idea and hope for the best.
ORD Connect:10.08.01.033
MS Connect: 10.14.02.01
Projectwise: 10.00.03.49
Hi Ole Bro,
Did you review this https://communities.bentley.com/products/microstation/b/microstation_blog/posts/new-in-microstation-connect-edition-update-15-export-import-variables-and-variations-to-and-from-excel
as far as I can see you can import the excel file .xlsx and variables and variations will be imported to the active DGN and will appear in the variable dialog
Maria
Maria Garcia
