Hello
Is it possible to work like at autodesk with dynamic blocks?it looks like a parametric cell but it can be ordered at sight or by entering the dimensions
there can also be an interaction with the environment, that is to say that this cell could stick to a line which becomes its reference, for example a door can adjust as well to a horizontal or oblique line, scketchup the also done.
thank you Laurent
No, MicroStation does not have this functionality with Cells. It has been discussed & requested many, many times, and there probably is a service request in existence for the functionality to be added, but I wouldn't expect it to come to fruition, any time soon.
yes don't hold your breath waiting.for that... but at least we can edit text in cells with the text editor.. never used be able in the old days... and you can use the fence stretch tool to modify most cells that I wished were dynamic block types... but I agree it would be welcome addition .. possibly CE50 or more ....
Lorys
Currently Using V8iss10 (8.11.09.919)
and dabbling in CE update 16 (10.16.00.80)
and now
Pwise Administrator ( yeah I passed the training course!)
Laurent Marseille said:that is to say that this cell could stick to a line which becomes its reference
This should be possible with Mstn using Constraints. Mstn's Constraints have more options compared with what is available with ACAD Dynamic Blocks, which are 2d only.
OBD U8/ Mstn 15.2. The problems start when the user saves the contrained geometry as a Cell (Parametric) so that you can re-use the constrained Cell elsewhere without having to re-apply the Constraints. Once the Cell is placed, you will find it difficult to grab and modify the LIne which is nested in the Cell. Modifiying nested elements seems to be possible in Parametric Solids saved as Parametric Cells, but not when regular geometry is constrained and saved as Parametric Cells. Hopefully something that will be fixed in future.
The other bummer is that when the Cell is dropped, the Constraints are lost. Apparently this WAD, which I can't see being very helpful. If the user saves the constrained geometry AND inserts the Cells as Parametric Cell then you would expect the parametrics to be available. It might be helpful to help save space by stripping the constraints info but this can be easily accommodated by providing the option to place Parametric Cells as dumb Graphic Cells in the Place Cell tool.
These obvious gaps have been pointed out years ago now. Hopefully to be resolved soon.
Mstn constraints: so much power yet so unusable.
Constraints Cell to Line.dgn
