NEED HELP.
I am encountering an error in opening the software that is shown below:
Warning: minor version mismatch. Program=(10.16.2.251). Resource File=(10.16.1.319)
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\ustation.rsc
also, during prinrting a "fenced drawing", onother error came in as shown below:
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\ustation.rsclog4net:ERROR XmlHierarchyConfigurator: Cannot find Property [createpath] to set object on [log4net.Appender.RollingFileAppender]
What is ther main cause of the error, and how to elliminate this error?
Thanks for your help.
Edgar Padre
Hi Edgardo,
When did this issue start occurring? Was there a recent upgrade to new version of MicroStation CONNECT?
It is possible that this file is bad or did not get updated with a MicroStation upgrade.
You can try replacing this file from machine that has the same version. If that does not work I would suggest uninstalling MicroStation and removing the C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation (just the "MicroStation") folder before reinstalling.
Regie
