I am trying to Paste an Excel table in Microstation Connect using Place Table feature. I have set all formatting like row height, column width, bordering, etc in excel as I want them to look in Microstation. And I am preserving formatting while placing table in Microstation. The problem here is that when table pastes, the row height automatically increases for every row in Microstation. I tried to reduce the height mt reducing the height of the whole table but it will not go below a certain threshold. I have some 80 rows and 61 columns.
Desired: ( These values are set in Excel)
height of each row = 0.19 inches
Total height of table= 1.48ft
What I am getting: ( In Microstation)
Height of each row = 0.21 inches
Total height of table= 1.671 ft
Does anybody know what is happening here and any help would be appreciated!! The laptop I am using is i7 16GB RAM. Could this be the issue and require higher processor because currently it takes light years to paste and the place table function is quite fickle and breaks the sheet if used multiple times consecutively.
Thank you
I have a similar issue with MicroStation tables
In sheet space I made a table with no seed using a text style set for a height of 0.07 inches (L070)I copied the table from my excel sheet and pasted (ctrl+v) it into the tableEverything looks good but the cell height is too big, there is too much space around the textI select the cell (or even the table) and try to change the cell height from 0.2331 to 0.2 to see if that will tighten it up but it will not get any smaller
Another issue.....I created a row above the table for my header and typed in my texti wanted it to be a little bigger (no problem there), wanted it to be underlined (no problem there), I wanted the underline to be offset a little more but no mater what i set it to it does not move
Service Request number 7001406938
4428.TABLE TEST.dgn7142.TEST TABLE.xlsx
FYI As shown in Service Request # 7001406938 this has been reported a Bug # 874421.
