Hello all!
Have a Great of new year?
When i performing project, always need to calculate Feet to meter.
because *Need to fix meter unit of master Model(Owner don't want to change to feet)
So When i drawing line in Microstation distance(Inset 3.28 feet), is it possible to Automatically convert to 1Meter?
Best Regars
Why not change the working units setting from/to feet/ meters, do your work in the units of your choice and then change it back again before returning the file to Owner? Microstation automatically converts units on the fly.
Great Idea but he usually want to check beside of me.
Max is correct. What you could do is create a dimension style which displays lengths in metre’s, or both feet and metre’s, one length above, another below.
Ah, tricky! That was one of the advantages of Covid lockdown - being able to work in isolation without over-the-shoulder surveillance.
Barry Lothian said:What you could do is create a dimension style which displays lengths in metre’s, or both feet and metre’s
FWIW we designed AreaAnnotator to show dual metrics...
