When selecting linestyle. I got few duplication of same linestyle appear. How do I remove it ?
Cheers
Andrew
Could it be that you're pointing to multiple RSC files or folders containing your Line Styles? There may be multiple RSC files containing Line Styles with the same name. Have a look at what the configuration variable MS_SYMBRSRC is pointing to. Are there multiple folders listed?
Hi Andrew, thank you for answering my question. I have checked and I do have multi RSC files in the folder that I am pointing to. But those linestyle are not even in my RSC. Could AUTOCAD setting will cause it ?
rgs
Line Styles can also be contained in your Design Libraries (DGNLIB), as well as the DGN file, so you might also need to see whether they are coming from the DGNLIB files in your workspace. I would not think that AutoCAD would contain these Line Styles.
You will have to determine where these line styles are coming from. Using the Line Styles dialog you can check this see below:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v19/en/LineStyles.html
If defined in multiple resources you may have to do some cleanup so they are no longer listed.
Hi David,
That's a great advice. I have open the same drg in connect and the issue is not there (Great). The issue happen when I open the drg in v8i SS10.
Could there is bug in v8i ?
