When selecting linestyle. I got few duplication of same linestyle appear. How do I remove it ?
Cheers
Andrew
Hi Andrew. the same drg open in connect is fine (no duplicate appear). The issue happen when open in v8i SS10.
Any thought ?
rgs
Hi Andrew,
Andrew Tan said:Could there is bug in v8i ?
Well, it can be, but - based on my experience - likely not ;-)
Further testing is required, using MicroStation V8i:
Not everything is automatically "bug in a product", often workspace configuration is not right, or there a minor incompatibility / conflict between workspace and DGN content.
When you open the file in CONNECT Edition, you changed context (workspace configuration) completely.
With regards,
Jan
You will still need to try David's suggestion to find out where these linestyles are coming from.
It's far less likely a "bug" in V8i than it is that your V8i and CONNECT configurations are not identical.
MaryB
