workstation directory empty
When I start Microstation, it contains none of the Workstations my company uses. I also own OpenRoads and can find all relevant Workstations there, so I think the problem is the file path that MicroStation follows specifically. I'm wondering if some fiddling I did around with file paths earlier led to this. Does anybody know what the file path should look like and how I can fix MicroStation?
