I like to start Place Composit Curve with the method 'Line segments' by default. Is there a key-in or setting to do so? In previous versions you could use mdl calculat, but this mdl doesn't excist anymore.
Hi Paul,
Paul Haffmans said:I like to start Place Composit Curve with the method 'Line segments' by default.
try
place composite;set item toolsettings compcurvemodeoptionlabel=3
Paul Haffmans said:In previous versions you could use mdl calculat, but this mdl doesn't excist anymore.
It still exists, but you do not check CE documentation for changes. It is now integral part of MicroStation, so to load calculat application upfront is not necessary.
With regards,
Jan
Key-in the following:
place compositeset item toolsettings compcurvemodeoptionlabel=3place composite
For more info see How to extract keyins for the tool settings in MicroStation V8i
Hi Jan,
Thnx, that works fine. Sometimes it's quicker to learn from a colleague then just reading all the papers:-) It gives you an extra point of view.
Hi Ron,
Thanx for the info I've got it working.
