Does somebody know why my level manger wont open just my level manager flyout?
I have just downloaded version 10.16.02.36
Try UPF related, RestoreDefaults (one at a time) and check if the dialog loads.
Note: Your current User Preference settings, will be lost when you perform a “Restore Defaults”.
Thank you, Leonard, but it does not work... I tryed to do this changes in properties but it will not allow me...
Hi Sigríður,
Sigríður Brynjólfsdóttir said:Does somebody know why my level manger wont open just my level manager flyout?
I have not MicroStation PowerDraft installed, so I am not sure what differences exist in ribbon definition (standard MicroStation ribbon looks different).
But, under Level Manager button (pull down button), there are two icons available: One for Level Manager, and second for Level Manager Flyout. Maybe the second one was selected and active as default?
Jan
Thank you Jan,
Yes, under the under Level Manager button (pull down button), there are two icons available: One for Level Manager, and second for Level Manager Flyout. I don't know which one is the default one. Just that when nothing happens when I select "Level Manager" just when I select "Level Manager Flyout".
If the RestoreDefaults is successful, you will the following dialog
