When you attach a Saved View the view boundary does not display. Attach a standard view such as Top will display the boundary.
Works fine in V8i SS10.
/Krister
Some more testing.
This seems to occure when the model in which the saved view was created is empty but has a referens attached.
My feeling is that the boundary shown when you attached the saved view is created from the range in the active model only, not the range of all visible references. Add an element to the model and the boundary appears.
Owner consultant at Surell Consulting AB
While attaching Saved view as a reference it shows boundary when elements are present in ti
If a Blank saved view is attached to the model it will not show any boundary.(WAD)
we have check-in V8i SS10 it seems same behavior as connect.
If it is possible please attach dgn file or some video of workflow which you are trying
Attached is a video that show the problem.
Saved Views.dgn
