I was wondering if there was a change in MicroStation or a Microsoft update that affected the wms attachments? I can no longer view the wms imagery from any source.
Dan Messerich
Hi Oto,
you're right. We know that the WMS implementation of Microstation products is worse in the the last years. It seems there is no development .
But that does not help Daniel. He might open a service request with Bentley. Or trying the WMS source with open software like QGIS.
Frank
Frank Klein said:But that does not help Daniel. He might open a service request with Bentley.
It won't help either he will get reply that they tested it in QGIS and it works. No kidding, we are comparing top notch proprietary software with top notch opensource product and which wins? In QGIS we get full debug logs and requests to verify what is going on and it doesn't help either because there are no issues in QGIS.
After that they will ask to install Wireshark and log request locally(as there is no debug option in MS even that it explicity requests errors to be reported in XML). After looking into Wireshark log it will show that there are no issues of course because it is MS internal issue handling the requests. What is most stupid is that even if server responds with error it gets replaced with this stupid "crossed old camera" icon, same happens if it is internal issue so we have zero options to debug anything. PowerSurvey is discontinued without direct replacement so no fix. Lack of proper WMS support is Microstation trademark for years.
Daniel Messerich said:There is an error for every wms I try to reference.
That also doesn't mean anything because there are issues with the cached entries in WMS dialog and if you accidentally input wrong request then it is no longer possible to input correct one. Not sure how to clean the WMS dialog history.
Honestly WMS is not really supported in v8i it is in "lack of technology" preview state. Try to print with WMS background and you will get even more camera pictures even that it works in view. CONNECT is little bit better at least printing works but still the same hardcoded requests and outsourced suboptimal development. Some defects I reported are even marked as fixed but still the example WMS I sent doesn't work so it is not even tested if the fix is fix.
It has been discussed previously but the main issues in v8i are as follows:
What can be tried:
