I'm running a simple batch process with various key ins on a massive amount of files. I'm not super vba savvy so i'm not sure if i need one or not to answer this dialog box, but i've attached a picture of it along with this code:
View Off All;View On 1; Window Tile; Fit All; Selview All; Selview 1; MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 DataFields False; selview 5; set ed off; MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Fill True; selview 5; set fill on
CT=C:\UstnV8i\WorkSpace\System\data\color.tbl; WT=0; LC=0; LV=C-COMM-OVHD; CO=12; FILEDESIGN; FT=7
MDL SILENTLOAD FINDREPLACETEXT,CHNGTXT CHANGE DIALOGTEXTFIND DIALOG SEARCHSTRING THE DOW CHEMICAL COMPANYFIND DIALOG REPLACESTRING DUPONT DE NEMOURS, INC.CHANGE TEXT ALLFILTERED
set levels off=Level 2; selview allset levels off=Level 4; selview allset levels off=Level 6; selview allset levels off=Level 8; selview allset levels off=Level 10; selview allset levels off=Level 12; selview allset levels off=Level 14; selview allset levels off=Level 16; selview allset levels off=Level 18; selview allset levels off=Level 63; selview all
LOCK GRID OFF; LOCK UNIT OFF; LOCK AXIS OFF; LOCK ASSOCIATION OFF; KY=2
RF=MS_REFLOCATION:MYLARBP.3D,default,BORDER,Master Model,View 1
FILEDESIGN
Cole DeBolt said:MS_REFLOCATION
That's is, presumably, your configuration variable?
If you key-in MS_REFLOCATION:MYLARBP.3D,default,BORDER,Master Model,View 1 manually, do you see that modal dialog?
Yes it is.. i decided to omit all the extra's.. border, master. I realized i don't have an end of argument in there. it does bring up the dialog.
RF=MS_REFLOCATION:MYLARBP.3D,,,,, I didn't have enough arguments. I kept playing around with this all week. lol. i just figured it out before you wrote me back. Thank you,
sorry but you don't seem to explain the actual solution so others could benefit
is the answer
so it doesnt wait for the ok?
Lorys
I’ll attach a good communities discussion that shows how to do this, it’s very helpful. I’ve been organizing these in bookmarks for later reference.
communities.bentley.com/.../keyin-to-attach-references
good old ask inga... I had that page printed out and pasted in my scrap book
yes I knew the generic answer of the 5 commas, but your post didnt make it obvious or easy for newbies or others with search for similar problem and solution..
RF=TEST.DGN,,,,,
Note that you need 5 commas to get past the attachment dialog and OK button
personally for a keyin I would put the full path in inverted commas (not MS_REFLOCATION is that a variable? ) but
RF="F:\projects\1234567\xrefs\MYLARBP.3D",,,,,
