Ho una linea lunga 145 km, dovrei inserire una tacca e un numero sequenziale ogni 1000 m. Come devo fare?
Translated I have a 145 km long line, I should enter a notch and a sequential number every 1000 m. How should I do?
I'm thinking the best tool to place points along a line at a distance would be the "Construct Active Pnt @ Dist Along Element" tool.
- Sto pensando che lo strumento migliore per posizionare i punti lungo una linea a distanza sarebbe lo strumento "Costruisci Pnt attivo @ Dist Along Element".
How to create points along a line
This won't place a value of the distance along the line but that could be performed after placing the cell / element using this tool.
- Questo non posizionerà un valore della distanza lungo la linea, ma potrebbe essere eseguito dopo aver posizionato la cella / elemento utilizzando questo strumento.
Grazie mille per la risposta. Funziona se crei una cella speciale (tacca e numero) ma devi inserirle una alla volta e non metterle perpendicolarmente alla linea. Non c'è altro modo?
post a screen shot of what you want it to look like for the first point at 1000m and second point 200m.. this is beginning to sound like stationing or chainages, Now without seeing your dgn I imagine doing it like this.
I would place/ draw the first line or notch and copy 15 times with the copy tool ( 15 number of copies) at 1000m via the accudraw.. then I would place the first text 1000 at the first mark or notch and use the copy increament 1000 tool there is a sneaky keyin that would let you use the pipe command so it does it 15 times at 1000 m apart but for 15 times just as easy to do by hand and use the snap tool..
The above method only works for straight lines..
Now for complex lines the place active points along is good to locate the points then you can export the points by their xy coordinates into the export coords tool and create a csv file for editing in excel then you can use excel to create a text column and add 1000,2000,3000 then import the data back to label the points..
to place a notch or short vertical line create a cell and use use the points tool but choose cell at 1000 m interval along the line...
If you need more or better explanation please pm me and I'll try to help better in Italian but I'm very rusty with written Italian but I'm a fluent speaker no dialeto. maybe with Skype...
Lorys
Ciao e grazie per la risposta, come richiesto, ti mostrerò una schermata di come vorrei segnalare i segni di chilometraggio. Fino ad ora li ho creati con un lisp Autocad, mi sembra strano che non esista una modalità automatica con Microstation Connect o V8i.
Luca Ricci said:Fino ad ora li ho creati con un lisp Autocad, mi sembra strano che non esista una modalità automatica con Microstation
With AutoCAD you wrote a LISP macro, but you expect MicroStation to match your requirement out-of-the box?
Here's a VBA macro that lets you place points along a line...
