[SS10] Array along path into Graphic Group?
I need to place a lot of barrels in a construction zone. The Array Along Path tool is great for this, however, it would be nice if all the barrels along any one path could be saved into their own Graphic Group.
I'll admit, I am woefully ignorant of Graphic Group usage. I was scared away from them after some disastrous unanticipated consequences early in my career. I'm still leery of them because there is no visual clue when an element is a member of a GG, but I will admit there are times that it is nice to have elements treated as one large group instead of just a bunch of single elements. Due to my ignorance, I am unsure of the ways to create GGs, or if there is a way to do so somewhat automatically.
The other option that would be nice, if it is possible, would be to make my array Associative to my path. I don't see that option in the tool settings, so I assume it's not possible...But could I be wrong?
I am using MicroStation and/or Power Geopak SS10. Thank you.
  • Hi Mary,
    Associative I believe isn't possible. Not sure why you want to use Graphic Groups, going from what you say, Named Groups sounds more like it would be useful to you
  • Actually, named groups would be a pain. I am going to have dozens and dozens of runs of barrels, and coming up with names for all of them is extra work I don't care about. And a Named Group is little more than a graphic group with extra work, for all I can tell.
    The only reason I was thinking of graphic groups (if there was a was to do that automatically) is that, when plans change, selecting and deleting all of the barrels in that area is tedious. Often, a few get missed here and there, so we have random barrels scattered about. If all of the barrels for a particular line of pavement marking were grouped together, they could be easily deleted when that line is changed. But I don't care about naming them; I can't even think of a workable naming scheme.
    The crux of this is that I was hoping it were something that could be done somewhat automatically. Having to select every barrel on any particular run, for every run that I need to do, to add it to any kind of group for future management is additional work.
    Placing and maintaining barrels is always tedious. My DOT has a custom linestyle for barrels, but they only come at one of two spacings, neither of which is appropriate for an urban job. Scaling the linestyle down to my spacing also scales down the size of the barrel points, which is less than ideal. Not to mention, the linestyle is just a little whacked. I believe this may be an issue with custom linestyles with points and no "lines", but I do not only get points where I want them, I get points at other, apparently random, locations, and arcs do not always display as I would expect them to. Or it could just be a poorly designed linestyle. My DOT does a reasonably good job, but everything is supplied as is, and a lot of it is a conglomeration of resources collected together by people who have neither the time nor the budget to sort through it all and completely standardize everything.
    When I talk about barrel runs, I am talking about the barrels along any particular stretch of line from "here" to "there". Eastbound white line between Shortridge Rd. and Franklin Rd. would have a run of barrels. Westbound yellow line from Shortridge to Franklin would have another run. Channelizing one lane for Berkley Ave. would be another one or two runs. some are long stretches, others are shorter, more specific to an isolated traffic pattern. Along Path has been a lifesaver for placing them, but I was hoping there was some easy way to manage them in any way after placement, instead of having to keep track of thousands of barrels individually.
    I do have ORD, if there are tools in CONNECT that can make this happen. We aren't using it for design, but I've been known to pop in when I need a specific tool to get a job done.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Those would be nice, but I actually do not need 3D - these are 2D representative plans, and will be for probably another decade at this rate. I'm not certain that would work anyways, because depending on speed, my barrels would need different spacing. I'd either have to make a linestyle for every possible spacing, or  my barrels would shrink as I scaled the linestyle up or down (which is where I am today).
    I am looking forward to this day, but I am afraid today is not it.
    MaryB
  • Mary,
    Ohio DOT has custom 2D linestyles for different drum spacings. I've attached the .rsc file if you want to use them.
    ODOT_Linestyles.rsc
    Matt
    Answer Verified By: MaryB
  • Nice!!!
    I'll have to add that RSC to our office library, so everyone has it. Thank you!
    MaryB
  • Maybe not helpful, but I placed a lot of barrels back in the day, I created a custom linestyle for the task. It's not like the contractor will use the exact depiction anyway. Coincidentally I was drafting per ODOT specs, before (and after) they published their CAD standards. They still use the barbaric color for pen weight standard, but you'll still be able to use their resource. They also have lots of other goodies, the sign library is quite a time saver.
  • Mary,
    I created a simple 2D line style (attached below) that places a 2 foot circle at the end points and each vertex of a linesting. You just need to use the Facet Curve command to re-facet the linestring using any Chord Length you desire.
    3125.BarrelStyle.zip
Reply
  • Mary,
