Hi
My question is about how Bentley software results is planned to be viewed by project members for free. Autodesk has Navis that comes with one version that is free viewer for all project members, then there is simulate and manage where you can produce information that you want to be shared.
How is it in Bentley software family? I know that there is some kind similar as Navis in "Bentley world " Navigator CONNECT Edition. Is this similar as the Autodesk Navis? If it is is there also an free viewer for navigator as there is in Autodesk Navis?
Every new big project that is started has an requirement that the information has to be able to be read/view by all project members without owning the full license of the programs used to design the result with free viewer.
Do Bentley have this kind of solutions?
Best regards
Tom
Equivalent to free Navisworks viewer is Bentley View. Bentley View costs $0, but users still need to sign up for an account with Bentley in order to use the free app.
Hi Tom,
To add to what Tuan already posted, Bentley View is available as a free CAD viewer:https://www.bentley.com/en/products/product-line/modeling-and-visualization-software/bentley-view
Here are some related Announcements/Blogs we would recommend to learn more about the product:https://communities.bentley.com/products/microstation/f/microstation-announcements-forum/174637/bentley-view-connect-edition
https://communities.bentley.com/other/old_site_member_blogs/peer_blogs/b/marc_thomass_blog/posts/bentley-view-connect-edition
The most commercially available version of Bentley View CONNECT Edition is Update 16 version 10.16.02.22
Thanks for all your efforts, but Bentley View is not the same as the Navis freedom, Bentley View is similar to any free dwg free reader out there. What I mean with free model viewer is that you can summarize 3d projects in one viewer. not one file at the time as in bentley viewer.
Tom said:What I mean with free model viewer is that you can summarize 3d projects in one viewer
You'll need to clarify what you want. MicroStation's idiom is to view multiple models as reference attachments. You want something different?
In fact this is possible in Bentley View using i-model. With an i-model made in Openbuildings you have the entire project in Bentley view including all the 2D drawings generated in the project.
