I'm seeing this modal dialog with the message VBA rejected the MicroStation Application ObjectMicroStation rejected the MicroStation Application Object. When I click OK the dialog immediately shows again in an endless loop. I can neither use MicroStation nor dismiss it.
Moderators: note that this is not a VBA programming issue. At the point I see that dialog, I haven't been able to use MicroStation.
I recently installed OpenPlant Designer to test some stuff. This problem occured after I uninstalled OPD.
I used the Windows Control Panel to Modify (repair) the MicroStation installation, which appears to have fixed the problem.
It is the beauty of VBA that some windows updates or other installations can mess up VBA registration.
Try to repair Microstation install seems OPD uninstalled also VBA.
Hi Jon,
There is an issue as of a few versions back that if you uninstall an Microstation PowerPlatform product you get this for all the remaining installations, very annoying.
Mark
Possible causes.
Following may help others…
If it does not work you may have to repair/re-install the product with Admin privileges.
