This Wiki
https://communities.bentley.com/products/microstation/w/microstation__wiki/26366/how-to-place-a-filled-background-in-a-text-frame-with-place-note
does not seem to work for me.
When creating a region the text frame is not recognized as an object to create a region.
Is there a setting stopping me from doing this?
Microstation PowerDraft CONNECT V10
Hi Joel, can you provide a DGN file where you are trying to create the region?
Text Frame with bg fill.dgn
This is how I do it in V8i:
Thanks for the reply Barry.
I can do this as well in V8i but it does not work in CONNECT.
The create region tool does not recognize the text frame as a valid object for creating a complex shape.
Hi Joel,
Can you please be sure that the "Locate Interior Text" option is toggled on in the Create Region tool? If you do not have this toggled on, the capsule will not be recognized.
Dan
Answer Verified By: Joel Zimmerman
