Microstation reference file presentation
Display style “Illustration with shadows” does not show up on sheet model.
Dialog set at synch view only, use view flags, update from saved view.
Pity as shadows make architectural façade drawings much more live.
Any trick around?
V8i
I can definitely see it listed in MicroStation CONNECT Edition (Update 16.2). Is there a possibility that you can supply an example design file as well as the version of software you're using.
