Hello Bentley Community,
I recently upgraded from MicroStation (SS10) to the latest MicroStation CE version. I'm trying to use my Axiom software with the new updated MS CE but it seems like the program is not recognizing Axiom. Has anyone here experienced the same issue?
Thanks!
Hi Luis,
Have you tried contacting Axiom directly with your issue? They would be best placed to advise if their tools work with your version of CONNECT.
Axiom has different versions of their tools for CONNECT
The V8i versions (32-bit) will not work in CONNECT (64-bit)
I recall there is a fee to upgrade each license to the newer version
Thank you David, I will reach out to Axiom directly.
Thank you Barry, I will contact Axiom directly.
