I am using the command 'SelectBy Attributes' to select all my Lines and Line Strings. I'm then using the 'Modify LineStyle Scale' command as shown below to change all of them to 50 scale. This works great and changes most of my LineStyles. But several get changed to 600 scale or don't get scaled at all. If I run the command several times all the LineStyles eventually get scaled correctly. Any help on getting this to work one time would be greatly appreciated. I'm using ORD but having the same problem with SS2. I can post this to those communities if preferred but seemed like a MicroStation issue so I posted here first. Oh, I uploaded my file also in case anyone wants to reproduce the issue. Thanks again for any help.
UtilityFile.dgn
Hi Corey
Unfortunately we can't see your Linestyles as we don't have your RSC file so the lines are all Linestyle 0 and 3 when I open the file.
I select the lines but I use the level or element attributes to set an the desired LT Scale
but it only works with custom lines ie not linetypes 0-8
I have changed the scale here manually to X8 under the line style parameters for a custom line called Barrier one way
Lorys
I tried this but it only allows me to edit one LineStyle at a time. The Modify LineStyle Scale allows me to edit all at once except for a few for which I have to run the command 3-4 times.
That sounds like bug #965 (not a real number, but it's big). Guessing you're using Connect.
I can also do it in the level manager provided all the lines all live in specific levels...
