Self Reference a file
I am self referencing a file.   Referencing a model view into a sheet view.  Lets call the file block.dgn.  If a make a copy of block.dgn and rename it to newblock.dgn the references of newblock.dgn link to block.dgn.  Is there a way to make the references stay within the file when a copy or rename is made?
  • Good point.  The seed file I have is a sheet view with title block and the model view.  Sheet view is setup to reference model view.  The file I am working I added extra model and sheet views.  Ended up with 2 models and 6 sheets.  One sheet is just an embedded excel spreadsheat the other five references a model or part of.   If I want to create a new standalone drawing that has 80% same geometry as the original and keep all the geometry in the same position on the sheet views, how should one efficiently go about that?
  • The geometry portion is simple. After you create your new file, you can simple model in the old one and either merge that reference or copy as much geometry as you need. This procedure filters out corrupted data (It's actually one way to try to recover data from a corrupted file).
    The sheets would be a little different, since I assume that your model references have been scaled and moved to your border. That would require repetitive rework to create from scratch. I would be tempted to import copies of the sheet models from the original files and just repath the attachments. That flies in the face of what we just said about clean fresh files...but often sheet files are literally just collectors of references with a handful of text. I don't see as much corruptions from those as I do design models. But I'd be interested in what others might suggest.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
