Hi All.
I have received a file with thousands of closed shapes. I need to change their fill types as I need their fill to have a colour. Currently they are all not filled. Any ideas of how to do this in bulk instead of clicking on one at a time please?
Michelle
I have an alternate method that may work (or may not) depending on the file you're working with.
I had hundreds of open lines that depicted rebar and i was able to isolate the rebar with display set, draw a temporary box, select everything and create a grouped hole with interior shapes. I was then able to drop the hole and was left with the right number of complex shapes.
