Early Connect edition functions, where are they or have they ever existed?
Hi
I have to ask about some functions that I have been told that they existed in Early version or Preview versions of connect edition releases.
1.The first question is CIVIL ACCUDRAW , was this implemented in some early versions of Connect?
2.Second question is about V8 Task, was there in the first releases of V8 Task even the drop down menu also included?see image what I mean:
If these where implemented in early Connect editions, why do they not exist anymore?
//Tom
  • I cannot find any documentation that the Civil Accudraw too, available in the Civil products like OpenRoads, was ever implemented for use within MicroStation CONNECT Edition. You might like to post this as an Idea for inclusion in a future release.
    MicroStation Ideas
    As for you second question, there were a number of changes to the way that the inclusion of V8i Tasks were implemented in MicroStation CONNECT Edition. I would suggest you have a look through the current information for how the V8i Tasks Theme operates in the latest releases.
    Enable V8i Task Theme in MicroStation CONNECT Edition
    Andrew Bell
    Technical Support
    Bentley Systems
  • Hi Andrew
    Thank you for the replies on my questions.
    for my first question about civil accudraw I have following question.
    Would it be possible to implement civil accudraw to Microstation Connect?
    if yes the next issue is post an idea to Bentley is one thing, to see in your lifetime to see your idea be implemented is another thing, sorry but these things with ideas from regular user is not so inspiring from the point of view of the average user, it is completely unnecessary to put forward new ideas. It takes a very long time for new functions, regardless of whether they are ideas from regular users or come from another source.
    But thank you for the suggestion about civil accudraw .
    The second question about the V8 Task menu.
    I don´t need to know how I find how the V8 Task is working just now because I know how it works right now, what I wanted to know was what I heard there was a version where the menu part was included, if this version was an update or preview.
    I don´t know if the Preview versions documentation always was up to date (where this menu was present), so therefor this question is for the users that tested microstation from the beginning if they remember seen something when they tested early preview/update versions.
    //Tom
  • Tom,
    The  V8 menus were not added to Connect. So they have not been present in any version of Connect.
Reply Children
