Hi
Based on another thread in this forum, I found out the actual level on an element can be added to an ItemTypes using following expression:
this.GetElement().GetDisplayString("Level")
That's great!
However, I'm new to Expression Builder and need a hint or at least to know if it would possible to get the "Level Description" and not jsut the Level name.
Any idea?
Re Mikkel
Mikkel Bennedbaek said: I found out the actual level on an element can be added to an ItemTypes
Please tell us what you want to achieve. Why do you want to 'add the actual level on an element to an ItemType'?
If you're writing a Report, then you can already add level info...
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
At Atkins - member of the SNC-Lavalin Group, we work flexible hours around the world. Although I have sent this email at a time convenient for me, I don't expect you to respond until it works for you.
NOTICE – This email message and any attachments may contain information or material that is confidential, privileged, and/or subject to copyright or other rights. Any unauthorized viewing, disclosure, retransmission, dissemination, or other use of or reliance on this message or anything contained therein is strictly prohibited and may be unlawful. If you believe you may have received this message in error, kindly inform the sender by return email and delete this message from your system. Thank you.
Mikkel Bennedbaek said:It is not the Level Name I am after but the Level Description, as that, in my case, contains relevant information I need to export to IFC. Is it a two step process? I mean, can I get the Level Description if I know the Level Name using expression?
I think you're on the right track. Given a level name, it ought to be possible to look up its description in the DGN file's level table. But what that Expression should be I don't know. Something along these lines, but this is conjecture...
this.GetDgnFile().Levels.FindLevel (this.GetElement().Level).GetDescription()
this.GetElement().Level gets the element's level name.
I can't see how to obtain a level description. For example, Expression Builder tells me that this is OK, but in practise yields no result...
this.GetElement().ActiveFile.Levels(this.GetElement().Level)
Perhaps Mangesh.Shelar can help?
David Trejo-Rodriguez said:You might want to inquire with our programming forum
I think a solution using an Expression would be the best result. A programmatic approach is overly-complex and not open to most users.
